Johnnygm7lsi
Hi there are simple books on lecy stuff or on line google,first amps & watts of power are basicly the same thing but volts is the shunt or driving force.
So a bulb at 100w driven by 230v simply divide 100 by 230 and o.43 will be answer which is less than half a amp draw of power.
So from here we can look at our van with a 12v battery at 100ah capacity,so if you had a tv running using 100w divide 12 into 100=8amps,now subtract 8 from 100 for every hour its running ie 5hrs tv 40ah which would leave battery almost half depleated.
If you have a volt meter fitted then watch as voltage drops to almost 12v from a full charge of about 12.8v its time to switch of or the battery will be damaged.
Next inverters are a electronic box of tricks which step voltage up from say 12v to 230v but in doing so loose some power by wastage,so 12v to 230 with a 100ah battery will give about a hour less run time on a 230v tv that if you had used a 12v tv and thats why folk as a rule buy 12v tv for van rather than use inverters unless your using camp sites plugged into ehu 24/7 where the battery will be getting charged as you use it,hope this helps a we bit other here may be better to explain than i.
You should start a thread explaining MH electrics and get done as a sticky
