Renault Master PVC
Robmac
As some of you may know, I have just started to convert a 2012 Renault Master 2.3 DCI. It is a LWB version with an extra high top.
I have never attempted anything like this, so my mate Jim (Helmit of this forum) is helping me out, he completed his own conversion a while back.
Anyhoo, I thought I would record the conversion in a thread for those interested, and it will give me a pictorial record of the conversion, so here goes!
First of all, I stripped out the back of the van. It was lined with very thin ply which didn't cover the entire walls. I also removed the bulkhead between the drivers/passenger seats and the rear of the van. This gave us a blank canvas to work on;
I will not be adding a swivel seat, but the middle passenger seat will have it's rear squab removed to make a 'crawl through' access to the rear of the van in foul weather;
First job was to fit the floor. We used Stixall to glue 25x38mm battens to the metal floor;
Next, we overlaid the insulation. We used Premium Gold underfloor insulation from Harrison Trim Supplies;
We then laid 12mm WBP plywood and scred to the battens. I varnished all of the edges of the ply for further protection;
Today, we decided we would fit the windows. Quite scary when you have to cut holes in your van. I used 2 500x350mm windows for the washroom and sleeping end of the bed, and 2 700x500mm for the lounge area. These were all Seitz windows.
After a lot of careful measuring we cut the first hole. First we used a 25mm holesaw to cut the round corners;
Then, using a jigsaw the edges were cut;
Jim reckons my line was wonky. Personally, I think it's Jim's eyes being wonky as a result of many years of self abuse. But I wouldn't comment on that.
(OK it was a bit wonky, but soon sorted out with a file!)
Heeeeeere's Jimmy!
Several clamps were used to Stixall 18mm battens as an internal frame for the windows. These were space out with 6mm scrap ply for now. The windows have not been glued or sealed, and probably won't need to be (Thank you Mr Brown!). We will be removing them all to cut the ply lining apertures through the window holes (Thank you Mr Brown!);
And the finished job;
I will update the thread as we progress!
Going well keep going,one thing i would use 2/pack epoxy on wood rather than a single pack varnish,do both sides before putting down as epoxy seals very well as thats what wooden boats are sheithed in.
Your right it is scary cutting big holes in van even worse if its someone elses van.
Make sure you waxol inside those panels and around inner rear arches/box sections as it will sweat.
You will have to remove middle seat compleatly and lap belt or mot will fail you,good luck keep posting pickys.
Great start Rob. You will get no advice from me at any point in this thread. (In case you feel let down at some later point)
Look forward to reading about your progress.
Sandy
Why the radius corners, Rob? This is a test?
Looking good to date.
It matches the profile of the window's frame Terry. However, with the overlap of the frame you could possibly get away with square corners.
If anybody else has to cut out their own window's, I would definitely recommend wearing long sleeves, and a face mask/goggles. That swarf can be very hot!
Yup good un
Looking good Rob. Can't wait to see the finished jobby. Hope you are keeping Jim topped up in beer otherwise you will have a few more wonky lines in the future when he gets withdrawal symptoms.
.... Tom ....
Nice one Rob, however with that look on Jims face I think he must have been in the throws of self abuse at that moment, looks like you caught him in the act :lol-061:
Square corners are stress raisers, Rob. For example, boats/sailing vessels have portholes and, radius doorways, this design reduces/eliminates, stress raisers, which can be an issue when vehicle/vessel is moving and under stress.
Square corners will crack due to flexing, where radius corners are more forgiving.
More useless info............lol
Quite useful info Terry.
I will only have one doorway inside the van which will be into the shower/loo. I was thinking of making that a radius doorway, purely because I like the look of them, being a boating man. Now I know why they do it!
Thanks Trev.
The middle seat squab is easily removeable and replaceable, so I can put it back in before MOT due. :)
I'm hoping that the self adhesive foam/foil insulation will prevent a lot of the sweating, but I will look into it further. Luckily, the van has a galvanised body, so moisture is more of an issue for the woodwork than the metal. Thanks for the tip.
I see what you mean Mark. He looks like a Chinaman taking a dump!
Van looking good!
And what air plane was made with square windows and didn't do very well?
i never bother radiusing the corners, the van will be in the great scrapyard in the sky before it feels stressed, and it means i can cut out with a skinny bladed disc cutter because i don't like hot sharp swarf going down the neck of my shirt !
looking good Rob, very camp , i mean camperlike
Oh yes Nigel. I had plenty of the hot swarf.
In my face, on my arms, down my shirt.
Character building!
All this fitting out business has given me the opportunity to invest in more power tools for working at home, or at Jim's rather than the work unit.
Latest acquisitions are a Jigsaw, Circular saw and Chop/Mitre Saw and stand. I'm like a kiddy in a sweetshop!
It makes so much more sense than the food and clothes and other such nonsense that Julie buys.
no good having all that stuff for butchering wood if you haven't got a couple of makita impact drivers to put it all together again
