Hi, I have an RMD 7665L with similar problem to yours and have tried the following with some success:
1-Check for a good flame, and check for heat coming out of the external vent.
2-If flame is on but medium to small, you ,may have a partially blocked flue, which will need to be cleaned.
3-If flue is OK, and you have a good flame then gently tap the cooling coil unit pipes at the back of the fridge to dislodge any obstruction within the pipe system.
4-If the flue is OK but you have a small flame then you may need to replace the jet and igniter, do not attempt to clean the jet.
5-Check to ensure that the drain hole inside the fridge is clear all the way to the recepticle at the back.
6-If you have access to main hook up, set the fridge to main 240v and check the current draw, should be around 1.2amps, this will confirm that the mains heater element is working.
7-Check that the door seal is OK by trapping a piece of paper in the door, close the door and pull the paper out, if there is some resistance the door seal is working.
8- With all these tests, leave a fridge thermometer inside the fridge to monitor any changes, but dont keep opening the door frequently.
Hope the above helps, failing that you will probably need expert help.
Good luck, Lou:goodluck::goodluck:
