Inverter problems
Hi guys, the 2500w
inverter is just about large enough to run a toaster on its own, Or maybe just about a microwave on its own. If you intend to plug and play many different things you will need an
inverter about 5 times the size, at least 10,000w modified sinewave. Even then you will need to keep an eye on the specific types of appliance you use with it, as some types of electrical items will not like the wave form (for example toothbrush chargers will be damaged). I have a 8000w
inverter which is just about sufficient for what I am doing. I have a 1770 AH capacity
battery bank, with a separate pair of vehicle batteries another 220 AH. All these are
solar charged by two sets of three 100A flexible
solar collectors. 600a in total controlled by two waterproof MPPT controllers. The reason for this is, if I am parked near trees, a shadow might knock out the output on one set of panels, rather than loosing all
solar production. I would never connect the
inverter to the air conditioning It will pull vast amounts of amps and will drain the batteries in a surprisingly short time. I will attempt to explain why, 240volts * 10amps = 2400Watts almost the limit of the
inverter, but motors use more amps on start up to physically get turning from a stand still, but I will ignore this point for now. to achieve this 2400watts / 12volts = 200amps. The draw from 220 AH pair of batteries, theoretically would last just over the hour, but in reality the usable range is 13.5v fully charged to 10.5v discharged, to exceed this range will damage the batteries. So the usable range at max is 3V and the
inverter will cut out. The time this takes to happen will depend on the quality, electrolyte level and general condition etc of the batteries, and so I would be surprised if you got more than 20 mins. You can never use the
battery charger at the same time, the inefficiencies of the
inverter and charger will combine and flatten your batteries for you in next to no time. I Have an onboard generator for any Air-con, intensive cooking, hair drying women etc. The
inverter is used for microwaved quick snacks, super quick cut of tea with the electric kettle etc. Most of the time we use 12v appliances or gas. Even with training in power conservation the 5 of us use power at an enormous rate. I regret to bring more bad news about your
inverter but any appliance more than around 1000w will probably cause it to trip out if you are lucky, if you are unlucky it won't trip out, just melt down inside. The problem is with the initial start up I mentioned earlier. My best advice is to research your exact requirements and list them out, then do some more investigation on the internet what size
inverter is required for each item and choose the biggest affordable
inverter to run the specific must haves and scrap the idea of plugging in multiple items.
