condensation problem
A friend of mine lives in Oliver BC. He has a fifth wheeler with lots of vents so gets little condensation.
Having said that he spends the 6 cold months of the year in it in California.
Great looking camper.
The problem is ventilation and creating a thermal barrier between the cold and warmth. With the woodburner going it should create some draw from the chimney. It may be as simple as leaving a window open and opening up the woodburneer vents. I help fit a woodburner in a freinds cabin in Finland. The wood burner was off set and the flu ran diganolly accross the room. So lots of flue was exposed this created a hug amount of heat which normally would just go up the chimey. this would then offset having the vents open on the wood burner.
Also using a gas heater is bad as it gives off allot of water vapour, reason why gas is not used in roasting coffee. Not to mention the nasty gases.
(Sorry for any spelling mistakes)
Surely what he needs is a sufficiently powerful air con unit to dehumidify the air in the trailer. I guess he could only use this while on electric hook up. It might be expensive to buy and run. What are mains electricity costs like in Canada?
Dehumidifyers are not the awnser as the air has loads of water in it unless you want to suck the whole planet dry,unsulate and keep at the 21c temp constant like a house with proper heating controls,coal is bad oil or gas is best and thats why they dont fit new homes with coal as its from the dark ages.
we don't have double glazing but suffer from very little condensation, ventilation is the key and an all round heat rather than just one heat source in a particular area, we have small tubular heaters all round the van giving a reasonable background heat we very rarely need to us the diesel heater as the vehicle is well insulated and because of the all round heat no cold spots ,result nice warm van no cold spots therefore no condensation.
Is that the we green house heaters i see on ebay.
With a dehumidifier, only the barest minimum of ventilation is required, just enough to keep the air 'fresh'. That means that you don't need masses of continual heat to heat up the incoming "ventilation" nor to dry out any more moisture that the "ventilation" brings in. Ventilation is an answer but, in my view, not the best unless there are no other options, because it then brings other problems (cold, draughts, more moisture, need for more heat...).
People have said that, because the air is shared, you're then trying to dry out the whole world! Not so, because you keep the cold wet air outside and your dry warm air inside and only permit a tiny bit of ventilation between the two for freshness.
A side-effect of a dehumidified 'van is the really pleasant, almost warm, atmosphere when you step inside. Unheated, a dehumidified 'van is still a very pleasant place to be. You can't say that about any other motorhome in winter!
Finally, the smell... there isn't any if the van's dehumidified regularly. You know that "certain smell" when you go round looking at second-hand vans? Well there's none in a dehumidified 'van.
The temptation when using a dehumidifier is to seal off all ventilation - DON'T DO IT! You must have a tiny bit of fresh air coming in and also you really should use a carbon monoxide alarm in your 'van... everyone should, irrespective of dehumidifier use or not..
Barry
I found that good quality external silver screens cut down cab condensation , could you make some for side windows I found that internal screen made condensation worse . as others have said ventilation is key
yes they are the ones, we have 2 x 120 watt ones under our seat bases at front of van (ventilation boards allow the heat to rise between side wall and seat backrests) another in the bedroom on one wall (water heater the other side under bed) along with another in the washroom with a 60 watt heated towel rail, this creates an all round background heat with virtually no cold spots using a small amount of electric, to be honest we very rarely need to use the diesel heater unless exceptionally cold or off grid
