Relay
Hi everyone. I'm just in the process of self-building, and have purchased a Eberspacher Airtronic D2 diesel heater kit. The seller informs me it worked, and they had removed it from their van. It has the exhaust, fuel pump, controller/timer, etc. The loom is marked "Ford BT 185 Loom" and the heater is marked "Ford V1C15 9J294 AA" as well as the standard Airtronic D2 Eberspacher label. The heater has a 16 pin plug, connected to a 16 pin plug on the loom. Wires run to the pump, and the connector fits. Three other connectors are on the loom, a rectangular 6 pin plug (with 6 wires in it), a rectangular 8 pin plug (with 4 wires in it), and a round 6 pin plug (with 2 wires) which I think is a diagnostics plug. None of these connectors fit the controller/timer plug which is a 4 pin offset rectangular plug (with 4 wires), and is labelled "V1C15 18549 AB".
My question is can I butcher/adapt this loom to make it work off of a standard fused supply, or alternatively can I replace the whole loom and use a standard loom instead? Any advice from a knowledgeable individual would be greatly appreciated, or even advice as to who to ask. If required I can send pinouts of all the plugs, and pictures, but I thought it pointless unless someone has an idea of where to start. Thanks in advance, even if you only read this far.
