Watoh
Hi folks,
I've been putting this subject off for a bit.. but i need to bite the bullet and figure out my electrics. I'm starting from a real position of ignorance, it's my 1st motorhome and to be honest I'm not sure how it is meant to work.
Present situation:
Main engine battery works as expected, charges well, holds charge and does not get run down by the habitation area.
Leisure battery charges off the running engine only, does not charge when hooked up to the mains.
When on mains hook up the entire habitation area runs off 240 volts. There is a RCD in a cupboard in the habitation area.
Under the drivers seat is a "battery charger" labeled: Elektromatic LA 110 Batterie-Ladegerat made by Schaudt.
See image below
Here is where something is amiss. There is a black cable from the engine compartment that goes to the front of this box (the blue & brown cables seen above).
There is another cable that comes from the back of the charger and plugs into the white socket you can see in the picture. From this socket, the white cable goes to the leisure battery compartment with a 3 prog english plug that is NOT plugged into anything, there is nothing to plug it into. It would seem something is missing!
The leisure battery has a single cable connected to either terminal.
Can anyone explain this mystery of motorhome electrics please! I'm quite confused! I suspect it has been 'modified'. :idea:
Thanks for any help, i hope I have been clear in the present setup.
Cheers.
Present situation:
See image below
Cheers.
