Sharon the Cat
We have one of these, the valve was held closed by a cable tie when we got it. When the weather turned colder we took the cable tie off. When we went to drain down the system a couple of days later the whole water tank was empty.
Extracts from manual:
If the temperature at the safety/drain valve is less than 4°C, the water contents may discharge on its own accord if the appliance is not in operation (also if there is a failure)!
Without heater operation, the safety/drain valve can only be closed again at temperatures above 8°C!
I thought this was designed to empty the contents of the boiler only. Have I got it wrong and when the boiler empties the whole fresh water tank will eventually empty out as well?
If this is the case I suppose we need to keep the cable tie on when using the van but remove it when we park it up in winter???
I want to get this right because we are in the van tomorrow night & the temperature will definitely drop below 4°C outside. I don't want to wake up to no water for the kettle & no flush.
