Ducato Diesel Fuel Cap Leaking?
Alshymer
Hi
I am continually get a black oily mark around the fuel fill area and wonder whether the filler cap might be leaking.
Has anyone had this, found a method of repairing it or bought a replacement and managed to change the keys over?
Could be a rubber sealing ring worn or shrinking with the heat.
You should never fill a tank to the top and carry excess weight.
Hi
Something that can certainly happen is if you fill up say in the morning and it is a hot day, you can get a bit of an pressure build up and fuel can leak out.
If it is all the time, have you checked the rubber seal on the cap has not been knocked askew a bit and so not sealing properly?
Do you just fill until it cuts out or just anticipate what the tank will take?
Thanks for your replies.
There will be a vent so no pressure build up in tank.
Stop when it clicks, it clicks for a reason, this is why the diesel pump area is always slippy, which get's on your shoes, into the van/car and onto the brake pedal.
On our 2006 Peugeot Boxer based motorhome if i filled the tank ( first click ) then drove a decent distance say down to Canterbury when i got into Morrisons to refuel there was a loud hiss/rush of air as i removed the fuel cap, it did that from new until the day we sold it 18 years later.
You can still have this happen. I've had it a few times over the years on different vehicles.
Yes me to but i looked for a blockage and sorted it, some tanks do have a releaf valve which holds a small pressure to insure a pressure feed to the injectors, some cars have it.
There is no 'open' vent on modern vehicles, most times when opening the filler I get a slight inrush of air, might have had pressure coming out but don't recall it happening.
Ah well mine is old school and has a vent, dont like moderen cr-p.
