Engine temperature guage no working
UFO
The engine temperature guage on the dashboard is no longer reading. Its a 2009 Fiat Ducato campervan, 100 JTD 2.2L Ford Puma engine.
No warning lights on.
When I checked the coolant resevoir it was just below the minimium line, which has never happened before. It needed nearly 1.5 litres to fill it to the maximum line. I've not driven it since so I don't know whetherthe level will go down again.
Looks like a leak as well as a faulty sensor / guage / wiring.
Any ideas?
Stole this from elsewhere - also a 2009 Fiat Ducato. (snipped the relevant responses)
"It will most likely be the engines temperature sensor has failed.
To check it remove the wire from the sensor and touch it to the engine block. The gauge should show maximum temp"
"As far as I remember the temperature sensor is to the rear of the head top right.
Readily available on eBay but it's a big nut size"
As I posted on another thread, rad leaks on the bottom corner are quite common on this age of van, I'm not sure if this would relate to the temperature gauge, or if that's just coincidental.
p.s. on the 2.3 there's a plastic tray under the engine on the drivers side, on ours the tray had a puddle from the leaking rad.
If the fluid level fall below the location of the sensor then the sensor will not send a signal to th gauge.
My advice ie to use radweld, top up with coolant and then go for a 10-15 mile drive.
Disconect the Positive wire on the cab battery leave off for 5 min reconect and see if that helps, or do what Robmac says and that should diagnose if your sensor is faulty
Thank you for all the ideas. I will investiage further later this week.
Here's where I am with this -
1. Coolant topped up
2. Van driven until engine warmed up to normal
3. Engine temperature guage still not working
4. No sign of water leaks with engine warm and running
5. No drop in the coolant level
I would appreciate it if someone could tell me where the temperature sensor is on the engine block (2009 Fiat Ducato, 100 JTD 2.2L Ford Puma) as despite searching I can't find it. A photo would be very helpful.
Never had a Ford diesel but look for the water pump (its pulley will be driven by the V belt driven by the crankshaft. There will be a fitting with a wire going to it (there may be 2 of them actually). That is where you will find it.
According to Google AI
On vehicles like the Fiat Ducato 100 Multijet / JTD, the 2.2L Ford Puma engine does not use a traditional coolant immersion sensor. Instead, it uses a Cylinder Head Temperature (CHT) Sensor. This sensor screws directly into the metal of the cylinder head to monitor its temperature without making direct contact with the coolant.
Sensor Location Right Side of Cylinder Head: The sensor is located on the right side of the engine block when looking at it from the front.
Component Placement: It is positioned tightly between the high-pressure fuel pump and the vacuum pump.
Accessibility: Access is heavily restricted. You will typically need to clear away peripheral wiring harnesses and utilize a deep socket or a specialized slotted flare-nut wrench to remove it.
The sensor has a two-pin connector.
When the CHT sensor fails on this 2.2L Puma engine, it typically defaults to extreme readings or breaks communication with the ECU.
Because the ECU relies on temperature data to calculate the fuel injection mixture, a bad sensor will cause hard starting conditions and a severe loss of acceleration or limp mode.
As I am having no issues with the engine performance, or any dashboard fault lights, I am wondering whether it is the guage itself.
When the hailstones stop I will have another look!
The problem has now been investigated by my mechanic. The problem is the gauge itself in the instrument cluster.
My question, which he could not answer, is if the gauge is not working will the orange warning light come on if the engine overheats?
If the answer is yes I can manage without the actual gauge.
Temp gauge on ours regularly plays hide and seek
The multi plug connector suffers from poor connection and static build up Apparantly...
Disconnect and a spot of switch cleaner is the usual remedy.
I considered one of the many different OBD port gauges available as a back up/belt and braces.
My advice is not to use Radweld unless you plan to scrap the vehicle this year.
Find the problem, fix the problem.
