Fancythat
When is a leisure battery empty?
When is a leisure battery at 80%?
baring in mind the last time I did any electrical work which was on a vdub beetle I set fire to it and it was write off.
Given that a modern motorhome's electrical system is infinitely more complex than that of an old VW, now might be a good time to admit that 12V electrics is not one of your strong points and quit while you are behind.
Yes very ineresting but, I am still none the wiser.
For instance can I use two 12 volt x 70 Ah wheelchair batts couple together in my van? How do I couple them? i.e + to -, or + to +?
can these be charged from my split relay? I have a williton split charge relay charging my vehicle batt and my present 70 amp LB. Do I just join the other two LB's on the end of the line? what cable/fuses do I use? baring in mind the last time I did any electrical work which was on a vdub beetle I set fire to it and it was write off.
