In case anyone doest watch the vid right too the end it isn't just using power banks connected to EHU socket that may be unsafe but also if you connect at home with a 3 pin plug to EHU.
What I took from it is its down to the 3 pin adapter wiring Barry, will let Phil answer your question, it is down to grounding. Watch the vid againInteresting. I never watched it all but I have a 3 pin plug to EHU adaptor which very occasionally if I am plugged into someones house or once or twice in a farm yard etc I have plugged into a domestic socket through a window.
I Got the impression though that the issue was because the powerbank is floating in that it has no ground but a house does doesn't it?
The house is a grid supply and is what the EHU point is designed for....I thinkInteresting. I never watched it all but I have a 3 pin plug to EHU adaptor which very occasionally if I am plugged into someones house or once or twice in a farm yard etc I have plugged into a domestic socket through a window.
The problem is using a powerbank to the EHU.
Yes Millions of people have died, none due to this mind.Has anyone died?
I've had a shock off a 3ph 415v supply and I'm still around to tell you it 'stung a bit', but I very much doubt anyone in their right mind would recommend it as 'safe'.Has anyone died?
Yes dont do that.Mmm my heeds spinning. I’ve plugged from the inverter in to the vans hook up point to run the aircon a few times so is this the same and I shouldn’t be doing that.
Yes, plugging your EHU lead into the house using a 15A to 13A adapter is essentially the same as plugging the EHU lead into the dedicated 15A circular socket on a site.So one appliance good, two appliances not good but what about a normal hookup cable plugged into a house with a normal plug? I always assumed that was safe as its no different to being plugged into a hookup point is it? Just a different connecter surely.
Merl take another look at the video, its at the end after the main discussion on it I think. The 3 pin socket Matt uses to connect his ehu socket at his house could give the same fault as the adapter on the power bank from what they said. To make this safe he is going to install a ground spike at the outside socket, this in effect then becomes the same as an on site EHU socket. You need to have another look as its a bit beyond me but from what I am taking fro it you haven't quite understood what they are saying.Yes, plugging your EHU lead into the house using a 15A to 13A adapter is essentially the same as plugging the EHU lead into the dedicated 15A circular socket on a site.
What's different is a power bank or inverter doesn't have one side of the supply tied to the earth terminal and the supply is floating with no live and no neutral, just a floating 230v supply.
The 'double fault' scenario is the major risk with a floating system. For it to occur you need 2 METAL bodied objects to develop the correct fault AND they need to be plugged in and powered up AT THE SAME TIME. And you need to touch them both at the same time. If these faulty items were used whilst on conventional hook up they'd trip out so in that sense your items are 'checked' so to speak whenever you use them.on conventional hook up.
You can see that you need a perfect storm to get killed, it's highly unlikely BUT possible and being shocked hand to hand is particularly dangerous because your heart is directly in the current path. Using double insulated plastic toaster/kettle combo removes the risk from those items.
I think I'm correct in saying that the Victron inverters actually bond one pole (the neutral) of it's supply to the earth via a relay when being used off grid. This is to retain the same safety designs behind our home mains systems. I've contemplated doing the same thing to my vans inverter setup but not got around to it and it's currently floating. I'm not unduly worried though because only my oven has a metal earthed body. I'm also a thrill seeking adrenaline monkey who likes living on the edge.
