argoose
Hi, after a bit of insight. I went up MH to do a check around. Omni step came down on command. Checked volts for Cab and Leisure, both showed full 13+v on solar.
Exited van the step would not retract. Started van buzzer sounded and step retracted. Step would not come down on command. Tried interior lights on cab battery, bright but dimmed quickly. Ok on leisure battery. Looking at volt meter on control panel. 12+v, but dropping to 2v when operating step switch or lights. Recovering to 12+v when not under load. The only check I have done is voltage at fuse by the spilt charge relay but unable to check load voltage, as I was alone.
I am thinking there is a short some where between split charger and control panel above Hab door Or poor ground.
2005 Ace/swift Napoli on 15 mwb Ducato''.
Any thoughts would be greatly appreciated.
