Pudsey Bear
Yeah, but god help you if it needs any welding.
Those ones are chucked together, compared to the Morelo's.Here's one that better shows the build process for an A class, the base vehicle stops above the engine bay, they even cut away some of the steel in the pillar area, so no way is it stronger, form over function really.
Could well be, but I reckon those side panels are pretty stiff, and A class and coach built have a stronger chassis than a panel van, even factory cab chassis.For strength a van conversion would probably be best.
Yes, looked into it before I bought current van. It's a great option, but far too much for me to take on as a DIY.You can buy those insulated composite/sandwich panels cut to size Mark, they'll even cut the window/door apertures for you and then all you have to do is bond them to a floor and add appropriate extrusions and you have a box. (probably a lot more to it though.
I got a quote for the panels once but I can't remember how much it was but not outrageous.
I reckon they don't make a different chassis other than for length, and that'll be a chassis extension, too expensive.Could well be, but I reckon those side panels are pretty stiff, and A class and coach built have a stronger chassis than a panel van, even factory cab chassis.
Peter, (Listerdiesel) built a very strong trailer for his industrial engine, he use a honeycomb panel and aluminium extrusions from AALCO.You can buy those insulated composite/sandwich panels cut to size Mark, they'll even cut the window/door apertures for you and then all you have to do is bond them to a floor and add appropriate extrusions and you have a box. (probably a lot more to it though).
I think you will find they are slightly different, barring the Iveco Daily which still use an old school chassis, and is a true body on frame.I reckon they don't make a different chassis other than for length, and that'll be a chassis extension, too expensive.
