My Netgear used to work for hours on single charge, even when constantly being used. Also without an external aerial its positioning within the van could affect its performance. So unless you are intending to connect it to an external aerial its would consider not having it permanently connected, thus allowing you to position it as required.I’m planning to swap from Teltonika to netgear nighthawk which seems to work right out the box but want it on 24/7 so need constant feed
If only it were that simple. USB runs on loads of different voltages, all the way up to (and beyond) 20v. Especially USBCBut remember USBs work on only 5.5v not 12v.
I saw no mention of USB C.If only it were that simple. USB runs on loads of different voltages, all the way up to (and beyond) 20v. Especially USBC
It's actually in the title of the thread BillI saw no mention of USB C.
Perfect,thanks
You can't have looked hard: I mentioned it in the post you replied to, as well as it being the subject of the thread.I saw no mention of USB C.
Sorry, but that is just plain wrong. It may have been true once, but not for several years.Standard usb run on 5-5.5 v.
USB C can run up to 20v
A standard USB port provides a voltage of 5V. The maximum current and therefore power output can vary depending on the USB standard and port type. USB 2.0 ports typically provide 0.5A (2.5W). Newer standards like USB 3.0 and USB-C can deliver higher currents, up to 0.9A (4.5W) or even more with Power Delivery
Here's a breakdown:
- USB 1.x and 2.0: 5V with a maximum of 0.5A (2.5W).
- USB 3.0: 5V with a maximum of 0.9A (4.5W) for standard ports, and up to 1.5A (7.5W) for charging ports.
- USB-C: Can support higher voltages and currents with Power Delivery, potentially up to 20V and 5A (100W) or more.
I tried to run my nighthawk M6 from a usb-c socket with a usb-c to usb-c cable, it said that I was not using the correct power socket and wouldn't run, thanks, I will try this
Use the same for my Nighthawk M2.
