ProDave
Skip this first paragraph if in a hurry, it gives some background. I have 2 batteries in the the truck, set up by previous owner, the 12V starter battery and another lead acid leisure battery to power cab gadgets and a general purpose inverter in the cab. (also a third battery in the habitation unit). These 2 truck batteries are charged from the alternator with a split charging setup. There is also a volt meter in the cab in a not very convenient place, and I noted it is often showing less than 12V, sometimes as low as 11.5V but everything seems to work including starting the vehicle. But yesterday I decided to investigate and found it was the starter battery reading under 12K if left for a while.
So starter battery if left for a while (3 weeks since last starting the truck) was reading about 11.5V but it still started the truck just as normal with no hesitation cranking. So assuming it is a typical modern vehicle that drains power all the rime for things like the alarm, after sitting a while It was nearly flat. So after confirming it started the vehicle okay, I put it on charge with my battery charger and left it on charge all day.
This morning it is already back down to 12.0V I expect another day or 2 it will be under 12V again.
This has me puzzled. It it not normal behaviour. Not normal in the sense that whenever I have had a battery drop in voltage like that, the battery is on it's last legs and really struggles to crank the engine over. But this one although reading low, does not flinch in the slightest at starting and had it not been for that voltmeter in the cab, I would not even be looking at it. I have had this truck for 8 months now and I am sure it has been like this all that time and even in winter starts perfectly.
So how can a battery consistently read a lower voltage than it should, yet seemingly work in every respect and even hold enough charge to start the vehicle after 3 weeks? The conflict is I would expect a battery reading low voltage to struggle starting and not hold charge, but this battery does hold charge and starts fine so why is it reading low?
