MPPT to Battery cable size
Boris7
I’m fitting a Victron 75/10 MPPT that will draw power from a 125w panel.
This will connect to an EcoFlow and to the vehicle starter battery, the main aim is maintain the starter battery during long periods of non use.
What sized cable should I use between the victron and the battery?
The run is short (1m max)
I’ve got some awg8 which I believe is 10mm but it seems too heavy
Solar panels usually come with 4mm or 6mm cable on them, I haven't seen bigger than that but that doesn't mean there aren't any. 6mm is overkill but will certainly be enough
I gather the important bit is the bit from the controller to the battery which is the question here. Thats where it should be thicker especially if its a fair distance (more than a couple of feet). Least thats what Wizard Merlin taught me. :)
Do you think there is a massive increase in power after the controller? You would need a very long run of cable before 6mm isn't enough of a 125W panel :)
Edit: Bit of reading for you Barry
Cabling from the solar panel is already in place, tiniernet tells me I should use awg8, which I already have what’s making me think is this
Yes that's 4mm near as dammit, I used 6mm as its what I already had
Personally with lead acid I think the voltage drop at maximum current should ideally be no more than 50mv, it's not so critical with lifepo4 because they are less fussy WRT charge voltage, so with lithium up to 100mv.
A 125w panel will theoretically give a max charge current of around 8.5A but in reality will probably be around 7A.
With a 2m run of 4mm cable (1m there and 1m back) you'll get 65mv drop at 7A, OK for LFP but if you can get 6mm into the terminals I'd use that, especially if I were charging Lead acid.
There's a useful voltage drop calculator here
Thank you
It's not really about power loss Neil it's about communication. If the charger (be that solar or whatever) doesn't 'see' an accurate representation of the actual battery voltage at it's terminals then it'll stop charging sooner than it should. This slows down charging time.
We've all seen the slight differences in bulk/ absorbtion voltages on gel, flooded and AGM batteries, sometimes varying by just 100mv. It's completely pointless trying to be that accurate if you've already got say 300mv of error between battery and charger!
On the charger INPUT side though you're dead right, it's all about power loss. When I did the calcs for Robs van he had over 800W of solar and the cable runs were very.long, probably over 5m, 6mm was more than good enough,
You could have fitted a votronic mppt which charges the starter batt, or run a thick wire to a switch/relay from hab batts to starter.
