Victron MPPT default Bluetooth password hack
barryd
Bizarre one on FB this morning. Someone is claiming their Victron MPPT controller has been hacked on a French Aire and the name of the system and settings changed so they can no longer get into it.
I suspect its been a mistake. I think the default password used to be 00000 and I wonder how many there are out there where the owners have not changed it. My recent one came with a sticker and unique Bluetooth password which is now stuck on the wall next to the controller. I wonder if someone parked next to them has accidently logged on thinking it was theirs and changed it all. Seems a bit far fetched for a malicious hack but the reason for posting it is in case anyone has left theirs on the default. Seems an unlikely thing to happen but clearly it can.
My Victron MPPT password was changed by someone soon after I had it installed, made no difference to the working of it so I haven't bothered changing it to something I know, apparently easy to do, I think you need the serial number from the back of the unit.
At Silves we discovered our battery BMS settings had been changed.
Barry you can regain control by using the PUK code on the device itself, if you can’t find the PUK code you can contact Victron and they can unlock the device for you.
Yes, you can reset a forgotten Victron code and regain access to your device. This typically involves using the Personal Unlocking Key (PUK) found on the device itself, allowing you to reset the code to its default setting. If you don't have the PUK, you can contact Victron support or your dealer for assistance.
It wasn't me Bill, just someone on Facebook. I posted it in case others might have the same issue and it seems its more common than I thought. As said the bluetooth code on mine was already a unique six digit number so should be ok.
Yup the cerbo gx 2 I've just bought to replace a raspberry pi4 running venus
Came with it's own 'unique ' code rather than the earlier units 4/6 digit generic code .
On a French aire recently, I discovered a third Victron device showing up in my app; not mine, so presumably someone who had not changed from the default. I had quite a struggle getting password changes to stick after my system was installed, but eventually succeeded. Good that Victron have gone for something more secure on more recent supply.
The Victron app will always show nearby devices (including your own of course). It doesn't discriminate and could not do so anyway. How else do you discover a new Victron device you've added?
Access to all Victron devices requires PIN input which is why the old default value MUST be changed.
More nonsence to go wrong, im staying with simple things that work for me.
More nonsence to go wrong, im staying with simple things that work for me.View attachment 142676
Victron equipment comes with a five year warranty for a reason Trev, it rarely goes wrong. And if it does their warranty support is well known. But anything which uses Bluetooth sends out indiscriminate signals to all other Bluetooth receivers such as tablets, mobile phones or laptops.
So you should never leave any Bluetooth equipment using default codes, you should always change them if possible. But Victron have now went to the lengths of giving each and every piece of equipment a unique code, something very few manufacturers have done. They recommend that you then change their given code to one you will remember.
The advantages of Bluetooth far out weigh any disadvantages in terms of additional control and increased options it offers. But if you don’t fancy using Bluetooth they make some of their equipment without it including their MPPTs.
The advantages of Bluetooth far out way any disadvantages in terms of additional control and increased options it offers. But if you don’t fancy using Bluetooth they make some of their equipment without it including their MPPTs.
I must admit I didn't like the idea of an app and I used to love my old controller on the old van with its LED screen which gave you all the stats but the app is better to be fair. Until some French bloke resets it that is. :ROFLMAO:
VWALLA Monsieur 🇫🇷
Also Barry if you have other Victron equipment such as a B2B you can network them using Bluetooth. I find this enhances their performance when working together this way.
My simple sys works 100% running a votronic mppt regulator amd i dont have or want a smart alt, never had a flat battery as yet all year round. :)
I’ve become a Victron convert, all the stuff going into my Iveco build is Victron, mostly secondhand, I got two faulty Cerbo GX for peanuts on eBay one was any easy fix the other Victron replaced foc, brilliant service.
My Crafter is all Renogy (insert suitable expletive) it used to be cheap and ok for those on a budget but now it’s often as expensive if not more expensive than the infinitely superior Victron kit.
You can’t change any of the BT settings zero security however that’s rarely a problem because Renogy BT connectivity is absolutely appalling and the bloated social media wanabee Dchome app equally abysmal.
The devices are completely open to anyone however they need to be with about 2M to have a fifty fifty chance of even connecting!
Worse of all though is their customer support puts the emphasis on the customer proving there’s a fault via multiple evidence emails and videos.
I will be sticking with Victron from now on…. I just need to get them to sort out the annoying buzzing my 14 year old multiplus makes 😀
while we were parked at Silves tim pat & myself all had our fogstar batteries discharge turned off ! seemed to be completely random no other action taken there is a method of password protecting it but fogstar done recommend it because if locked out the batterty has to go to them to be reset they are apparently working on a simpler protection
