guerdeval
No it was getting pretty noisy despite the insulation, from what I’ve read on the web it’s pretty much ‘plug and play so if I slacken off all the pipe work which passes ‘through’ the insulation I’ve read that it’s a matter of the blue clips popping off and back on the new one, just hoping someone had done a similar task , thanks for replying.I'm not familiar with the Flojet. Can you access fixings and connections without removing the insulation?
Replacing a water pump is not normally difficult with the potential exception of needing to be a contortionist and/or having tools suitable for restricted access. Presumably the insulation could be removed, but perhaps only by surgery.
Out of interest, prior to the jackhammering, did the insulation effectively eliminate the sound of the water pump?
Thanks, this one is 50 lim I was thinking of lowering to a 30 lpm and save £60 !Make sure you replace like-for-like.
Don't be tempted to use a higher pressure pump. This may cause plumbing leaks elsewhere...
Try sliding the top insulation out, put a hacksaw blade or sharp knife to separate any glue used then do the same with the sides and lift over the pipes and out. Then the dog can see the rabbit!So my pump has been noisy for some time (think jackhammer) and has recently started to NOT switch itself off after running the tap so I’ve found it under a bed and boy has it been installed well, the insulation cann’t be removed so my question is, can a total incompetent change it for a new one?View attachment 136868
Good idea but they went to the trouble of making a hole through the insulation and the plywood so it doesn’t come off until i remove the pipes same goes for the electric feed, I’ve a new one coming so I think I can just mirror the removal when everything has been loosened off,Try sliding the top insulation out, put a hacksaw blade or sharp knife to separate any glue used then do the same with the sides and lift over the pipes and out. Then the dog can see the rabbit!
You usually screw through rubber grommets mounted into the chassis, a large washer on the screw and leave the grommets un squished it lets the pump float somewhat. Probably best to wait till you've got the pump and see what they include.
Those squishy rubber hobbies left quite slack would be quieter than ordinary screws for sure Rob. With domestic shower pumps nothing beats a piece of that flat green underlay between pump and floor boardsI remember we discussed Well Nuts for this purpose Merl - do you reckon they would work? They seem to be holding my awning rail firmly, but of course that is also sikaflexed.
