Fisherman
I did have a problem making connections to reversing light, but that was due to a lack of slack on the cable and the awkwardness of getting to it, but the job was really simple taking about 90 minutes and saving me £250. The kit cost £49 from Amazon.
The rear bumber had to be removed but that involved simply removing 8 bolts 4 from the top and 4 from underneath the van. There are even marking inside the bumper showing you were to drill the 21mm holes using the drill bit supplied by Dolphin. I mounted the sounder on a rear panel in the bedroom, and it can still be heard clearly with the engine running. When finished I managed to get the control panel and excess cabling into the rear light void area with no issues. I had to adjust the sensitivity so that you get a continuous sound one foot from an object.
You can buy a kit for an additional £10 with a visual indicator, with built in sounder, but I felt that all of the hassle running cabling to the dash from the rear of the van was not necessary. However if I change my mind I can buy the indicator and replace the sounder. You can also but extension leads if they are required,
Dolphins warranty lasts for as long as I own the van.
DPS400 4 Parking Sensor Audio Kit
The Dolphin DPS400 is a 4 recess mounting sensor high quality system that will cover the widest range of cars and give a professional finish. Included with the 4 recess sensors is a buzzer which bleeps with increasing frequency as you get closer to an obstacle. Features Include: 4 Rear Mounting...
The second photo shows the small sounder, the control panel is situated inside the rear light void 15 inches below this.
