Steve and Julie
I've bought a victron mppt controller to replace the pwm already fitted to our van.in easy terms how do I do this or is it best left to a auto electrician. All help greatly appreciated
Yep, it does, if you trace the 2nd red cable (the one going to the battery symbol), does it go to either a switch.or a fuse?Hope this helps
Make sure you change it to something memorable.The default code for victron is 000000.
Obviously, hence why I stated sort out your settings.Make sure you change it to something memorable.
You don't want some mindless tw*t to connect to your controller and alter the settings...
My twopenny worth, I think the connections themselves are all the same on any I've fitted,Hope this helps
As soon as you remove the wires from the controller it will be disconnected.Thanks for all your replies I'm off work Monday so will give it a go .
So I don't have to disconnect the leisure battery then?
Ideally yes, that's why I asked if you had a switch or a fuse you could pull on the red battery feed cable. If not just carefully remove one cable at a time and tape the end so it can't short to anything else. As you've already been advised disconnect the panels first and re connect them last.Thanks for all your replies I'm off work Monday so will give it a go .
