davef
I have just replaced the alternator on my mk3 Transit. Noted it wasn't activating the split charge relay to charge the leisure battery, and found the inline fuses had blown - I put 2 of 30amp fuses in parallel. I assumed there must be a short in the wiring and checked this out, but there doesn't seem to be a wiring fault. The alternator is 70 amp, but cann't see all the power going to the leisure battery, but then it occurred to me once the voltage is high enough to trip the relay, the twin starter batteries are connected to the leisure battery which could allow a very high current if the leisure battery was low. 60 amp is probably the maximum the wiring would take, so cann't just increase the fuse size. Should I just carry spare fuses for when this happens, or is there a way of limiting the current? Or is this an inherent problem with split charge relay set-ups and why battery to battery chargers are better?
