Bus bars ?
Lower Resistance bus bars for 12v invertor out of aluminium or copper as gold is to expensive.
  • My Make they fitted them by (installer's)
    Votes: 0 0.0%
  • Copper 10mm bar
    Votes: 0 0.0%
  • Aluminium 10mm bar
    Votes: 0 0.0%
  • Aluminium is best
    Votes: 0 0.0%
  • Copper is best
    Votes: 0 0.0%
  • Would love gold
    Votes: 1 100.0%
  • Total voters
    1
  • Poll closed .
1 Cup
I need bus bars for M10 connectors lugs for invertor 70mm wire is copper less than aluminium in resistance ?
What is in your van and would you now upgrade ?
Rob has this type.
As Neil suggested I'd make my own busbars from some flat strip, 20X4mm will have a CSA of 80mm so will be greater than your cables. Aluminium is about 1/2 as good as copper so if you make your ali busbar twice as thick (8mm) as a copper one then the 2 will perform similarly. Ali may work out cheaper for you.
FWIW Gold is actually worse than copper at conducting electricity, Silver however is slightly better than copper.
The reason why you see gold on connectors is because it doesn't tarnish, not because it's a better conductor.
Be connecting 2 x 280ah battery's to 2 jkong BMS 200amp to 2400w invertor and hab electric system.so bus bars needed to run to smart shunt and mega fuse on. but wili have to be after bms not befor as I'd like it or should I buy a second smart shunt and fuse holder ?
I'll be at Jackson leisure tomorrow any discount codes available !!!!! ? Picking up cerbo and upgrading sc to 100/50 + extra b2b isolated if needed
