12v Universal USB C Laptop charger for van
barryd
I just bought a new Lenovo Thinkpad E15 to replace my aging Lenovo Thinkpad. Of course its now a USB C charger type. I can run it off my Bestek 300w inverter of course but for my old one I had a dedicated 12v charger which now of course wont fit.
Im thinking this one will do it. Charger says USB C, 20v, 3.25amp, 65w and this charger has those options. https://www.amazon.co.uk/Charger-Un...=12v+lenovo+usb+c+charger,aps,104&sr=8-3&th=1
It just doesnt list my exact model as being compatible. All the compatible ones seem older models so I suspect its just not been updated.
Anyone used one or have one they could recommend?
I have charged one of my 18v Dell laptops with a USB-C phone charger which is only supposed to output 12v, quite how that works I don't know.
In your case if it's correct output voltage, and USB-C then I see no problem.
Some years ago, I used a third-party 12v charger with my new Thinkpad T530. A couple of days from the end of the trip, on a very sunny day, the Thinkpad suddenly stopped charging. It also failed to charge when using a Lenovo mains charger. On return home, I was able to use it in the Lenovo docking station and had it repaired under warranty - replacement of motherboard. No clue as to what caused the issue, but I wondered whether it could have been due to high DC input voltage due to solar panels putting a good charge into the batteries and the third-party charger not coping. I decided to replace the 12v charger with a more expensive Lenovo 12v charger and have had no such issue in the many years since. Lenovo do a 12v charger that looks right for your device, but it is of course considerably more expensive than the LabTEC.
Thanks. Generally good reviews but a few saying it wont charge when in use and if you look at some of the questions and answers they are a bit concerning. Im wondering if I might be better just using the Bestek 300w inverter with this one. However Now would be the time to test a 12v charger I guess while its under warranty.
Im thinking this one will do it. Charger says USB C, 20v, 3.25amp, 65w and this charger has those options. https://www.amazon.co.uk/Charger-Universal-2016-2020-Thinkpad-Chromebook-65W/dp/B0BL3GC3N5/ref=sr_1_3?crid=3NG9437A3902Z&keywords=12v+lenovo+usb+c+charger&qid=1685636444&sprefix=12v+lenovo+usb+c+charger,aps,104&sr=8-3&th=1
The Amazon charger is no worse (spec wise) than the supplied one so it should be fine.
Personally I'd choose a charger that exceeds the device demand by quite a margin, especially as a cheap after market device from Amazon/Ebay so can I suggest you take a look on the thinkpad it's self for it's power requirements.
The voltage needs to match (20V) and choose a power supply that exceeds its demand (measured by watts or amps) by at least an additional 50%.
This one goes up to 90w. I think the thinkpad max is 65, 20v, 3.25amps. This one states 20v 4.5amps though but that presumably is the max (90 watts)?
We charge our laptop and lots else with a usb c PD charger . That one says usb c PD too, so it should be fine. Usb pd knows what is plugged into it and charges at 3.5, 5 , 9 , 12 , 15 , 20 volts dep3nding on what it is charging, at up to 5 amps. If the wiring to it is not up to 100 watts it will blow the fuse at 20v x 5amps. It's the solution to laptops and any usb c device.
Thanks. Which one says PD, the first one I linked to or the one above. I reckon they are pretty much the same.
PD is a bit of a red herring regarding your particular application Barry, go for the latter one you linked to at 90W.
The 90 watt one is pd. And the better. I have a 100 watt one by some chinese firm Baseus. It plugs straight into a cigarette socket. pd cables are male usbc both ends. I had to update my fuse. The cable was thick enough.
