They are badly corroded. If you intend to keep motor for a good while, look at brackets made from alloy. If from steel, have new steel galvanised.Sorry for delay , i need to
replace the metal frames that support the fresh and waste water tanks under the van due to corrosion ! Wondered if there would be dimensional drawings available to make new ones as i assume they wont be available off the shelf !
https://photos.google.com/share/AF1...?key=Y0FINEt3cmJhb1ZpbHBmQkdxRFBpQl9GcFdUMnlB
Why not Trev, I’ve been on RNLI Lifeboats where the hull and deck are made from steel and, the top structure, as in wheelhouse and engine compartment made from alloy.Yes galv after shotblasting, dont mix alloy with steel when mounting.
The boat on the left looks like a Tyne class, the one on the right looks like a Tamar class, both are all weather boats, the Tamar class was the replacement for the Tyne class.Was the boat class left on the picture.
Because you set up a battery, look up the galvanic table, years running a anti corrosive co, thats why outboard boat engines have anodes fitted to the leg.Why not Trev, I’ve been on RNLI Lifeboats where the hull and deck are made from steel and, the top structure, as in wheelhouse and engine compartment made from alloy.
It looks like he has been parking in it though,Trev, the OP is not sailing his MH in salt water.
Agreed, the section look badly corroded.It looks like he has been parking in it though,![]()
Still happens, there is some on my van where the builders riveted the skin to steel, not a good thing to do.Trev, the OP is not sailing his MH in/on salt water.
There are ways to get around what you claim, Trev. I’m a big believer in fit and forget.Still happens, there is some on my van where the builders riveted the skin to steel, not a good thing to do.
I had a support bracket break. I took the motor to Essanjay in Poole and they fitted a new bracket within the hour supplying and fitting a new bracket at a better price than I was expecting. I don't recall exactly how much but I think it was less than £50. They had the new bracket in stock.looking for help or advice regarding my Autocruse Starburst 2009
