merl
I don't know about north of the border but we just connect the meter straight to the CU. I dont know if the 'live' isolator they swapped/included is standard practice or not in Scotland but seems a handy accessory to have in the case a CU swap as there'd be no need to pull the main 100A fuse.I had an interesting observation yesterday in the house when the electricity meter was replaced ....
In the process of replacing the meter, the main switch between the Meter and the Consumer Unit was replaced by a more up to date design (the 13 year old one is no longer appropriate!) and even though it is a dual-pole type switch, they only connect the Live through it and the Neutral went into a new connector block giving a permanent Neutral into the CU.
Seemed a bit strange where there was a switched connection just ready and waiting to be used, but apparently this is Scottish Powers standard? Doesn't really make a lot of sense to me as the first place the Neutral cable goes to into the CU is another dual-pole Master Switch which DOES disconnect the Live AND Neutral and then to RCDs which disconnect both Live AND Neutrals, so a bit of a strange standard?
Being 'pre meter' I guess that live only switch has company seald to prevent tampering? It's an ideal place to bleed off free leccy and if it's installation is standard practice then I'd suspect quite a lot of let's say 'amateur wiring' going on.
