Okta
Don’t forget that any existing split charge relay will need to be neutralised when a B2B is fitted, otherwise you will have a feed back loop.Absolutely agree. When I installed an LB in my previous vehicle (a Mazda Bongo) I used a VSR triggered by a positive differential between SB and LB. I reckon the EC155 uses an "Engine Running" signal to trigger the relay so the scenario you describe is absolutely feasible; I had suspected as much when we arrived at site after 2 hours drive and the LB had a lower voltage (based on EC50 LEDs) than when we left home. I thought I was dreaming it.
Thanks for the pointer. Really appreciate having my thoughts confirmed. That is where I am heading.
Priority 1 = B2B.
Priority 2 = bigger solar (I have a compressor fridge so 100W solar not enough to stretch the battery to 4 days, which is my aim).
My concern is that if eventually the EC155 has to be ditched, would adding in B2B and solar controller piecemeal be wasteful in the long run?
[edit] I've been in touch with the van manufacturer. In fact it came to light when I asked them to quote for a Litheum upgrade and the quote included a ridiculous charge for supplying and fitting a B2B. I've since found out that they fit B2B now as standard. You've nudged me into chasing them again now that I'm better educated.
Thank you.
