trevskoda
I would say it is a cost excercise. I have a few PSUs of identical style to the ones in the Sargent systems. They are very cheap, especially compared to multi-stage chargers.Only10A from a 25A chargerOverstating current capacity seems to be standard practice with all the standalone chargers (Chinese) on ebay/amazon etc, they know that peeps with a DC clamp meter will be few and far between but I wouldn't have expected it from Sargent, very naughty.
In an earlier MH of ours I fitted some cheapo led replacements to the lights, the sort with multiple SMD leds, everything was fine when off grid but when we were on a site with EHU, the charger was on it's bulk phase and so eventually the system was up to around 14.7V and at this point the LEDs got so hot they unsoldered themselves from the board and fell off!
Maybe it's the fear of overvoltage that makes Sargent feel they have to use what's basically a power supply rather than a full blown charger? Who knows as it's not a choice other manf make and other than my LED experience I've never come across 14.4V+ affecting equipment, have you?
What Brand of Motorhome do you have? You might find there is a Mate 'n' Lock Connector somewhere lower on that white flex. You could make (or have made) a spur to come off that connector which would be the neatest way to do it.Ok my next step is to create a convenient mains power source for the new charger.
There's a mains plug v close to the wardrobe and the leisure battery lives in a decent space underneath the wardrobe false floor. I'm thinking of extending the mains power from the existing plug through into the wardrobe.
But I'm not sure how, or it's possible/wise to create a spur from the back of the plug. If I could do that, it would be easy to run cable down to near the leisure battery and install another mains plug from where the new charger would run.
I'd welcome any advice on how to convert the existing mains plug socket into one that will take the mains power another meter or so into the wardrobe. I presume that's doable.
View attachment 118207View attachment 118206
Interesting. There's not much slack on the white cable and then it's inaccessible for quite a distance, so I don't think I'll find a mate n' lock. The cabling on the plug does though does look quite tight, so squeezing in an additional cable might be hard. Instead could I break into the white cable and use some kind of mate n' lock device to supply the existing plug with a spur to my new extension? Maybe that's partly what you were suggesting? If so, I can't quite figure out the necessary bits from your photo.What Brand of Motorhome do you have? You might find there is a Mate 'n' Lock Connector somewhere lower on that white flex. You could make (or have made) a spur to come off that connector which would be the neatest way to do it.
This photo shows the connectors you would look for .....
There is nothing wrong with adding a second cable to the socket itself but be aware that those CBE sockets can be fiddly to work with.
I was wondering the make as I don't know if everyone who fits Sargents use the Mate 'n' Lock system as well? Autotrail do and it makes it quite simple to remove a 240V socket to work on.Interesting. There's not much slack on the white cable and then it's inaccessible for quite a distance, so I don't think I'll find a mate n' lock. The cabling on the plug does though does look quite tight, so squeezing in an additional cable might be hard. Instead could I break into the white cable and use some kind of mate n' lock device to supply the existing plug with a spur to my new extension? Maybe that's partly what you were suggesting? If so, I can't quite figure out the necessary bits from your photo.
Thanks again!
(My PVC is by Devon Conversions in Co Durham btw)
I read on some self build site to use 2.5mm. Would that be overdoing it? I'd prefer to use the thinner 1.5 mm when doubling up the wiring behind the existing socket. That would ease the fiddly task wouldn't it ?You simply run a cable from the socket you've exposed and your new socket and connect up at both ends. You MUST use flexible multistrand cable (referred to as flex) DONT use the flat grey stuff which is solid core.
Use 1.5mm.
If it is a spur off to use for the charger, then 1.5mm or 1mm would be fine. You won't be pulling anywhere close to the current that would need 2.5mm.I read on some self build site to use 2.5mm. Would that be overdoing it? I'd prefer to use the thinner 1.5 mm when doubling up the wiring behind the existing socket. That would ease the fiddly task wouldn't it ?
Slightly I guess and would be ok as long as 1mm is protected by the original 10A breaker. If the breaker has been swapped for a 15A breaker then stick with 1.5mm. OR remove the new socket if you sell the van.I read on some self build site to use 2.5mm. Would that be overdoing it? I'd prefer to use the thinner 1.5 mm when doubling up the wiring behind the existing socket. That would ease the fiddly task wouldn't it ?
The Breakers are the MCBs (Miniture Circuit Breakers) fitted in the EC155.I've already ordered some 1.5mm in the end.
Now to the breakers you mention. I'm really in unchartered territory (for me) here. So schoolboy questions follow. I don't understand where the breaker (that's a fuse, right?) would go. Am I meant to break into the spur to fit a 15amp breaker? What would it look like?
I now have the same 12V 30A Leisure LCD Battery Charger For Caravan Campervan etc to install that you recently purchased. Would that have a breaker built in?
You can see I'm a minus square one.
Great point; I am a Sargent EC155 user with capacity concerns. At the moment I'm blaming the lack of a DC-DC charger despite the vehicle being Euro 6 with a smart alternator, but this discussion brings the EC155 well into the picture.I would still not recommend using the Sargent Charger with Lead Carbon. It won't hurt it, but neither will it properly fully charge it.
The important thing is that the big killer of lead acid batteries is leaving them in a partially discharged state which the Sargent is obviously guilty of. Now this wont be an issue with Lead Carbon and the OP wouldn't now be faffing with alternative chargers in order to keep the battery from sulphation.
Agree, it's not perfect because you wont get 100% of battery capacity but the OP or anyone else using this Sargent charger doesn't get 100% battery capacity anyway and that's obviously never been an issue so WRT capacity so they wont know a difference anyway.
Fit a lead carbon is the simplest means to an end and will be an excellent recommendation to many.
If you have a smart alternator and no B2B it is quite possible that your leisure battery will be discharging into you engine battery whenever the engine is running and the smart alternator voltage drops. A split charge relay is a crude device that opens the way for current to flow in either direction, either to or from the leisure battery. They are installed on the assumption that all the time the engine is running the alternator will be producing power at a voltage of about 14V. However with a smart alternator this doesn’t happen, it will spend a lot of time switched down to a much lower voltage allowing a fully charged leisure battery to discharge into the engine battery. The smart alternator will say “thank you very much I don’t need to do any charging the leisure battery is doing it all for me” (this is a very smart alternator that can talkGreat point; I am a Sargent EC155 user with capacity concerns. At the moment I'm blaming the lack of a DC-DC charger despite the vehicle being Euro 6 with a smart alternator, but this discussion brings the EC155 well into the picture.
That's a new one on me, never heard of that happening, not saying it doesn't just never reading it on any forum.If you have a smart alternator and no B2B it is quite possible that your leisure battery will be discharging into you engine battery whenever the engine is running and the smart alternator voltage drops. A split charge relay is a crude device that opens the way for current to flow in either direction, either to or from the leisure battery. They are installed on the assumption that all the time the engine is running the alternator will be producing power at a voltage of about 14V. However with a smart alternator this doesn’t happen, it will spend a lot of time switched down to a much lower voltage allowing a fully charged leisure battery to discharge into the engine battery. The smart alternator will say “thank you very much I don’t need to do any charging the leisure battery is doing it all for me” (this is a very smart alternator that can talk).
My opinion is you need to sort out the lack of a B2B first. No point in having the worlds best mains charger if a split charge relay is sometimes pouring the power out to the engine battery. First I would talk to the motorhome manufacturer about why there is no B2B (sometimes called a power booster or DC to DC charger). This is not a new issue and they should not be selling a van with a well known problem.
Absolutely agree. When I installed an LB in my previous vehicle (a Mazda Bongo) I used a VSR triggered by a positive differential between SB and LB. I reckon the EC155 uses an "Engine Running" signal to trigger the relay so the scenario you describe is absolutely feasible; I had suspected as much when we arrived at site after 2 hours drive and the LB had a lower voltage (based on EC50 LEDs) than when we left home. I thought I was dreaming it.If you have a smart alternator and no B2B it is quite possible that your leisure battery will be discharging into you engine battery whenever the engine is running and the smart alternator voltage drops. A split charge relay is a crude device that opens the way for current to flow in either direction, either to or from the leisure battery. They are installed on the assumption that all the time the engine is running the alternator will be producing power at a voltage of about 14V. However with a smart alternator this doesn’t happen, it will spend a lot of time switched down to a much lower voltage allowing a fully charged leisure battery to discharge into the engine battery. The smart alternator will say “thank you very much I don’t need to do any charging the leisure battery is doing it all for me” (this is a very smart alternator that can talk).
Thanks for the pointer. Really appreciate having my thoughts confirmed. That is where I am heading.My opinion is you need to sort out the lack of a B2B first. No point in having the worlds best mains charger if a split charge relay is sometimes pouring the power out to the engine battery. First I would talk to the motorhome manufacturer about why there is no B2B (sometimes called a power booster or DC to DC charger). This is not a new issue and they should not be selling a van with a well known problem.
