Just a general comment .... when a motorhome is parked up, why have a
battery charger on the starter
battery anyway? the more important
battery in terms of value is the Leisure
battery. Does that have a
battery charger in it as well? (if not it should do).
It makes much more sense to concentrate on keeping the leisure
battery maintained, be it via EHU or
Solar, and then using some kind of method to use that same power to maintain the starter
battery at a good level. That method can be a manual one, such as a simple cable (fuses each end for safety) between the starter and leisure batteries, or an automated one, such as a Batter Master or similar, or ideally an Ablemail AMT12-2, which is programmable so you can configure to precisely your own requirements.
There are good reasons to keep a starter
battery in a charged state, and it is not just financial. The comment, slightly tongue in cheek (I hope!) that seemed to suggest it is cheaper to just replace the
battery than spend the money on charging it over a period of time, was silly and for some reason this thread has started to go down a path of working out the equivalent costs to compare. That may be an interesting excercise possibly, but so flawed it is pointless.
Reasons to maintain the Starter
Battery
1) so you can use the vehicle when you want
2) to avoid a potential large repair bill if you let it decline and try and start the engine with a low voltage. This is a very real issue on some Ducatos (and likely other Sevel vans) which should not be ignored.
3) avoid buying a new starter
battery prematurely as it has been left to discharge too low
Reasons not to maintain the Starter
Battery
1) ?
Cost of maintaining the Starter
Battery
1) If you use a Mains Charger, cost of charger, plus the electrical overhead of the power used
or:
2) cost of a piece of cable and two
fuse holders (manual maintenance method) as you are (or should be) maintaining the Lesiure
Battery anyway
or:
3) cost of a
Battery Maintainer/DC-DC Trickle Charger (automated method) as you are (or should be) maintaining the Lesiure
Battery anyway
Cost of additional power to maintain the Starter
Battery
1) If it was maintained by excess power from
Solar, that would be £zero.
2) If it was maintained via the Mains Charger to the Leisure
Battery, then you can base the cost roughly on the extra power taken by the trickle charger to send to the Starter
Battery. Each van will vary, but in my own case (I just looked now to check the last 12 hours), the Starter
Battery is taking around 5Ah/Day to maintain it at around 12.5V. More than I expected, but that is the number.
5Ah/Day at a nominal 12.5V is 62Wh/Day. Over a year (so you have not used the vehicle for a full year), that works out to be 22.6kWh/Annum.
22.6kWh at 50p/kW (we will assume that rate) will mean maintaining the Starter
Battery at a healthy state for a year has cost £11.30 for the year. This would be worse case scenario as if you have
solar, the
solar would be doing the work for a reasonable period and that maintanance has no additional energy cost. Assuming you are using the vehicle sometimes (!), there is no maintenance needed during that time.
A more likely cost for this starter
battery maintenance might be around £6/Annum to include a Winter Layover period with no use and poor
solar
Ok. For those who just want to jump to the TL: DR summary ....
DO NOT USE A CHARGER ON THE STARTER
BATTERY OF A MOTORHOME. GET A DC-DC
BATTERY MAINTAINER AND LET THE STARTER
BATTERY CHARGE VIA THE LEISURE
BATTERY CHARGING SYSTEM
and if the reply is "I am not charging the Leisure
Battery", then the answer to that is "Why the hell not if you think you need to charge the Starter
Battery?"
