Wooie1958
Does anyone have any actual experience of these batteries please ?
Yes, I have virtual identical batteries made by Leoch that I purchased from Alpha batteries. I recommend both the battery and the supplier. My 3 * 130Ah versions have been in-use for 3 years and still giving a similar capacity as when I purchased. I would always use a Victron battery protect device such as https://www.victronenergy.com/battery_protect/battery-protect . I expect to get 8 years minimum out of these batteries!Does anyone have any actual experience of these batteries please ?
I have no idea of the history of my VB or LB so might need to change them at some point, what are the advantages? and do they need any special charging?Agree, way way better battery for not much more money. No Brainer![]()
Around 5 times more charge/discharge cycles, 200 Vs 1200. ApproxI have no idea of the history of my VB or LB so might need to change them at some point, what are the advantages? and do they need any special charging?
Oh, and they plug and play and suit existing chargers.Around 5 times more charge/discharge cycles, 200 Vs 1200. Approx
Will accept bulk charge current for longer giving faster charging times.
Reaches it's full capacity with less absorption/CV stage charging.
Can sit at partial state of charge without sulfating at approximately above 50% SOC. This means they last longer and give higher power for longer.
Higher charge efficiency (storing and releasing the charge that's been put in) 95% Vs 85% approx.
Higher tolerance to deep discharging. Lead acid typically discharge down 50% whereas a LC could be discharged down 90% for the same level of ageing. This means that a carbon battery has nearly twice as much useable Ah capacity in typical long term use.
As far as I can recall Kev there is no info about the maximum permissible cranking amps of the usual suspects ie the Leoch AGM and Gel LC batteries so possibly not suitable as a cab batt?
Carbon battery tech is advancing fast and there's recently been several manufacturers releasing Stop-Start EFB batteries with Carbon technology, at present they don't seem to be full blown LC batteries, more a sort of half way house but they are relatively cheap and cost little more than standard lead acid.
