www.hozelock.com
But when you connect it you get full flow/pressure there is one available in most french hypermarkets which includes a tap![]()
Double Male Connector | Hozelock Ltd
The Hozelock Double Male Connector is a practical and durable solution for joining two hoses together using standard hose connectors. Whether you’re extending the length of your garden hose or making a quick repair, this connector is a must-have accessory for any garden. Key Benefits of the...www.hozelock.com
Thats the one either woolies or mine fitsThis is one I'm struggling with.
Is the connector for this the one on post#3, pushed into the opening?
Yes ...This is one I'm struggling with.
Thats what you need for the normal borne taps would push in But then you,ll need something to connect to thatYes ...
Could not find one to buy in uk prior to trip to France if anyone knows where reply me pleaseTadaah!
Just pulled into canal side Aire at Thaon Les Vosges (Eastern France) and yes, this is the connector needed here. Purchased at Brico Marche.
Looks like you,ll be heading to a Brico then I,ve noticed theres more in use now than I,ve ever noticed beforeCould not find one to buy in uk prior to trip to France
Definitely what WOOE1958 said is right but you can pay a lot less for perfectly satisfactory versions. Tool station offer a set of bits and pieces including what you want but no tap for less than three pounds. https://www.toolstation.com/plastic-hose-connector-set/p42950. I generally manage to buy several when I find them for a couple of pounds.![]()
Yes it would get the water out and you,d be able to control the flow but you,d have difficulty filling a bottle or fitting your hose to it to fill the vans tank. I,ve taken more notice since this thread started seen 4 all have been positioned close to the ground for some reason ?So any hozelock type spray gun as used for vehicle wash etc would work ? if you already have one
All the better for dogs to piss on them, I suppose. and you can't wash them off before connecting. No idea of hygiene, those frogs. At Canterbury they fitted a new tap away from the outlet and quite high up to avoid contamination from careless cassette washers and dogs. I did not see it until after I had filled up but I wash the tap with disinfectant anyway so no harm done.4 all have been positioned close to the ground for some reason ?
