If you want to piggyback my research where I looked at fill rate rather than the claimed psi as apparently that is a more reliable indication of its ability I choose a VIAIR 300P. You could argue it's more than I needed and I accept that but the brand is reliable if you want to start there, their range is listed at the bottom of the link.
* it recommends not using the supplied hose in sub temps if you are planning a winter trip to Scandinavia
300P is a larger powerful portable tire inflator kit that is capable of inflating up to 33-inch tires easily by simply clamping the power leads to your battery, connecting the tire chuck to the valve stem and turning the unit on. Tire pressure can be checked using the 5-in-1 Inflator/Deflator...
www.viaircorp.com
