It was getting a leak test although I could connect a bottle there or via the external bbq point if necessary or maybe Spain where cylinders are so cheapInteresting layout with third bottle
If I need to do it I will just get a local bottle regulator and connect that to the pipe if use for my cadac then back feed through bbq point. I have what I need for that and also carry a propane bottle regulator as my emergency should the bulkhead regulator failGood idea that about hooking up an external bottle if parked up for a long time not really wanting to pack everything up just to get some gas.
Might invest in a hose myself.
What thread are continental bottles please?
I think you may be able to reverse those figures going by a lot of the things I see on the net, probably one right out of fifty.Wish we were so adept at doing DIY gas stuff but we aren't so have to pay to get it done .
Has crossed my mind though that for every say 50 ? of you competents, there may be one gung ho fitting own gas system. I hope I am never parked next to them
That's a better solution - I put a bbq point in last year so LP back feed is easy enough.If I need to do it I will just get a local bottle regulator and connect that to the pipe if use for my cadac then back feed through bbq point. I have what I need for that and also carry a propane bottle regulator as my emergency should the bulkhead regulator fail
Is there a difference to having multi bottles? It has to Gill one before going to the otherTo clarify routeing.
The vapour outlet is the Alugas, the Alugas inlet is connected to the underslung tank liquid take off and the external fill point is connected to the underslung inlet?
Are you confident that the underslung cut-off won't operate before the Alugas fills up?
Only one way to find out,i did ring to dealers on mainland and they said should be ok but never seen any one do it,the liq take of as you know is at bottom of tank so should start filling alugas cyl from starting pump,and even if bottom tank stopped for a few seconds surly it will continue once top tank takes of more liq to its 80% stop valve kills the operation,then bottom will do same.To clarify routeing.
Two holes, if refillable aren’t they four hole like the Gaslow and Gasit Plus? In any event with a two bottle system you get gas in both bottles. Why is this different? That’s a genuine question not trying to argue, I can’t see why it would be any different.Yes - there's only two holes per bottle and I'm not sure it will.
