Motorhome questions
  • Thread starter Deleted member 56979
  • Start date
Have autotrail Miami have lost power to aerial boost box have checked fuses next door all ok but no power on booster any other fuse boxes ??????????????
First have you got a ohm/volt meter,if so try and find cable input and see if power is getting to unit,if so either the on of switch has gone down or the unit itself.
If all fuses are ok but no power at box then you have either missed one or there is a break along the line,a cheap meter can be got on the bay from as little as 3 bucks.
Have you been doing anything with the van that may have interfered with the supply to the Aerial booster box, changing a light or similar could have disturbed a connection most likely 12v supply is from the leisure battery.
Alf
Motorhome question
A mate has check the power cable coming to the booster and its dead that why fuses checked and all look in order but light in unit has blown
Have a test at both sides of the fuse as could be dirty corroded connection,also pull out and in the fuse as the blades some times oxidize.
Motorhome question
Thanks for replies have got power on unit below booster for front T/V and rear camera but booster dead ????????
Replacement required by the look of it,but open it up as there may be a internal fuse.
Best time to play with things, if it's broken , you can't break it anymore. Could be a blown internal fuse, popped cap or just a dry solder joint which finally gave up.
Could be quick cheap fix or NFF and replacement needed.
Motorhome question
Thank you all for replies perhaps time for auto spark to have a look
Is it a booster as in amplifier or just a power supply unit.Our tv has a power supply which you can turn on in the tv menu to power the actual amp which is in the aerial
Motorhome question
Jeffg,, I think its called a booster box this is powered by switch on unit cannot be switch on from tv, at meet w/e when tuning in told no signal but every van on site
could get picture have checked aerial cable all look good so only booster left and power light off
Rather than keep trying things it might be better to bite the bullet and call an Auto Electrician, Can you post a photo of the booster is it a Vison Plus booster.
Alf
Yes I think so have check all the junk books you get when you pick it up but not even a wiring diagram for Miami in the book well done autotrail
Motorhome question
Thank you for that will have a good look
