Glandwr
You might want to add it to a setup where you don't have full confidence in the batteries BMS to shut off cold-temp charging however so you can more accurately disable the chargers to prevent potential damage at too-low tempsIf the temperature sensor is performing temperature compensation of the charge voltage then no, generally temp comp is considered unnecessary with lifepo4..
The sensor is I think a high temp one fitted to stop the B2B boiling the old sealed lead batteries. It was fitted 2014 well before LifePo4 and its cold temp eccentricities was known. Think I'll get rid of it unless someone says Whoa!You might want to add it to a setup where you don't have full confidence in the batteries BMS to shut off cold-temp charging however so you can more accurately disable the chargers to prevent potential damage at too-low temps
Ideally you want a Lithium Battery to have that low-temp charging control built-in though (and even more ideally, integral heating pads) rather than disabling the chargers as that charging power can be usefully employing to supplement the battery power rather than just losing it entirely.
Impossible to judge unless we know exactly what type of sensor it is and how it functions.The sensor is I think a high temp one fitted to stop the B2B boiling the old sealed lead batteries. It was fitted 2014 well before LifePo4 and its cold temp eccentricities was known. Think I'll get rid of it unless someone says Whoa!
I think the newer cheap batteries now tend to have BMSes that are actually able to prevent low-temp charging, but I would be wary about how to check that. Maybe put the battery into a fridge and connect to a very low current charge and see it if disconnects at a set point?Impossible to judge unless we know exactly what type of sensor it is and how it functions.
Most likely? a thermistor (temperature dependent resistor) that links to internal electronics, but could be a simple bi metallic switch that opens/closes at a preset temp either hi or low. The lifepo4's should have an inbuilt low temp charge cut off but unless you're willing to spend the time and effort getting your batteries down to near zero and seeing what happens to the BMS you'll not know it's existence or effacacy so largely that's a case of fit and cross fingers! If the sensor is external and you have the interest/will/ arse you could remove it and put it in a fridge/ freezer/ and measure with a ohmeter.
The chances are a different device will need a different temp sensor as there are quite a few types around, all with their own calibrations. As an example, for some reason Victron use a different temp sensor on their BMV Monitors to their Multiplus Chargers. No idea why and the two different ones LOOK identical, but Victron are very careful to point out they are different.If it is a low temp cuttoff type you could possibly add it to the new setup to offer additional protection from low temp charging.
Yeh, I know,, the amount of different values of thermistor AND the fact that there are 2 different types PTC and NTC makes them pretty much individual for each use. There's usually a 5-10 fold markup on them when you buy them as a branded accessory as opposed to getting them from CPC or farnellI think the newer cheap batteries now tend to have BMSes that are actually able to prevent low-temp charging, but I would be wary about how to check that. Maybe put the battery into a fridge and connect to a very low current charge and see it if disconnects at a set point?
