Forgot to say that most quality 240v invertor's only pull as much charge as they require for what you are running.
If only that were true!... my business lies in the servicing, maintenance and procurement of off-grid installations and I'd love to get my hands on 100% efficient inverters!
On large inverters, say 5000 W and above, one does see efficiencies as high as 96%, especially with grid-tie kit.
BUT, you'll only get those efficiencies when the
inverter is running near capacity, so the "lost" wattage is more than many people on this forum would regard as their total desired load. (100 to 200 Watt). Typically, even with well designed, high powered, inverters you'll be down in the 80% area, and a standing load of 20W or so, just to power the
inverter circuit itself.
Then things get worse - that "lost" energy manifests itself in the form of heat, and we may need cooling fans to remove that heat from the electronics - guess where that extra energy comes from
The original question asked about a specific load - a laptop. The optimum answer depends on a number of variables - in particular - will the laptop be used in conjunction with other equipment that also requires a "mains" supply, external disk drive, scanner, printer for example?
Option 1: Use a "cigarette lighter" converter, for your particular laptop. Advantages: Pobably the most power efficient; it will be working at the load the circuits are optimised for. Disadvantages; how are you going to power any peripherals? You will probably be plugging into the engine starter
battery, rather than the leisure circuit. You could take so much charge from the
battery that you can't start the van up again.
Option 2: Use a 230V
(+10%/-6% - don't get me going on "harmonisation!) inverter into which you plug the "mains adapter" that came with your laptop. I strongly suggest a true sine-wave device.
Advantages: You don't have to buy a "12v" accessory for your laptop. You can plug in other things that require mains voltage - toothbrush chargers, mobile phone chargers, computer peripherals, blenders, whatever - whilst you're using the laptop. Convenience - we're used to the ubiquitous "three pin socket" - it doesn't need so much thinking about. You can hard-wire an
inverter into your van's system so that you have two 230V circuits available, one from the hookup (when you can) and another from the
inverter. Needs a bit of intelligent use though so you don't plug the slow-cooker into the
inverter circuit!
Disadvantages: This wastes power, and you don't have much to spare. Every device you plug into the
inverter circuit that then has its own voltage converter wastes power. The
inverter has its own power losses (see above). It's a single point of failure - if you've bought a cheap'n'nasty off fleabay and it dies on you - then you've lost all of your "mains" devices for the duration of your trip.
There is a third option - those with an elec. eng. background have probably worked it out for themselves - but admit it: it's not for general usage is it...? and will almost certainly void warranties if it goes wrong.
For these I have assumed that the engine is NOT running - the voltage spikes from an alternator are scary, and laptops are expensive. Your risk if you do!
Every person will have their own needs/wants/cash/stress/reliability matrix. If your requirements are "average" there's lots of ways you can cut it and get acceptable performance - as soon as you get specific then you can go very, very wrong.
Try and work out
your requirements of the system, read as much as you can, ask people with proven experience (not those just cut'n'pasting something off the net that they haven't understood!), and install something you understand and can work/live with.
Mind the gap between expectation and reality!
Mild Red
