Water tank
Mungo
I am going to sound really dumb but I recently bought a Fiat auto roller, there is a large water tank and under the other seat - a little tank- whats this for? I keep them both filled up & erverything seems to work fine.I also have no idea about the leisure battery, how do I keep this charged for power when not plugged in to the mains?! Our fiat came with no directions for use!!
Can you give more information?
Your post was not clear if each tank was under each seat!
Approximate size, as it could be fresh water holding tank or waste, usually waste is bigger than fresh.
I do not have a Fiat Roller so cannot tell you exactly without more info...
I am sure someone will advise you who knows on here, as there is a huge amount of expertise posted.:goodluck:
If you're not plugged into the mains the only way to charge youre leisure battery, is to run the engine or fit a large solar panel.
John.
Hi Mungo,
Auto-Roller are made by the Triango Group, it may be worth your while asking them for a manual for your model.
Wanderer
I have a main water tank under the bed, a waste tank under the floor outside and also a little header tank, approx 9x9x2 inches with three pipes, two at the bottom for water in/out and one at the top for expansion overflow and a filler cap, for the wet (pumped water like in a house) central heating. Just wondering if that's what it is??
What form of heating do you have?, or haven't you got to that yet!!
Fresh water tanks
I think you will find the tanks are linked together,
How big is the little tank - and how do you keep it filled up. Where is the filler cap.
