beejay
Hi. Is it possible that heat from the exhaust pipe running 1" below the side locker, would/could cause condensation inside it. I noticed water in the front section of the locker & condensation type droplets from halfway down on the inboard wall section immediately above the exhaust pipe. There was no dampness anywhere along the inside top, nor partway down the other walls. As there are no leaks coming into the locker from above, everywhere else is dry, & the seal is okay, nor holes in the base to allow road splash ingress, it's the only conclusion I can come to. If it's the case I'll make a baffle to cover that section of the ex.pipe. Any ideas, though the more I think of it, the more I'm sure it is condensation.
Hmmmm. Forget all that, I've found the problem. A small un-finished seal that isn't obvious until a lamp is placed inside the locker & then viewed from underneath. Tried to cancel this post, but even though the box says "Edit/cancel" I can only edit.
BeeJay
BeeJay
