n8rbos
Photos of my waste veg oil system as promised
what exactly have you done why dont you just pour the filtered oil into the fuel tank and have a second filter on the system i know you are pre heating it before the pump but you could do that with a heater inside the fuel tank instead of adding all that pipe work and tank
the reason i have done it this way is i don't want to rely on one tank.
if i have any problems with say the cold waxing up my lines or filters i can quickly shut down the veg oil tank, til its hot enough to unblock. if i (somehow put a heater&bought i presume)in the main tank theres still the problem of it staying warm to the pump(thus the oil dropping in temp and causing pump to work hard) my way everything is easy to maintain/use,no fancy bits to go wrong and heated to and from the pump thus lowering the viscosity to (i reckon)below that of diesel, again the pump works less harder.
if i carried out the conversion you suggest ,how would you start the engine initially from cold?would i be relying on the heater in the tank to heat the oil immediately to the pump? to purge my system takes 20 secs max. in the system you suggest vegoil would be standing in the lines and pump all the time and if it waxes or is thick the pump will have to work harder(this is why a lot of pumps prematurely pack up).how would the heater in the tank be heated? if electrically its open to faults, would the tank have to be removed to install heater?can i just pick a heater for the tank from any shop and install in 5mins? if i fitted 3/6 port valves they are electrically operated and open to expensive fault! my system was built for@£30 less than i 3port valve, its been run like this for 18,000miles/2yrs and works superb.
this is my tried and tested system and in no way am i saying anyone should copy me,just showing what can be acheived for so little and how i overcome problems associated with running in vegoil.
ps tuf177 is that oil still available i have tried to pm you, if you pm your no. i'll call you to sort it out!
tony
my only question is wheres the MOT station that passes that setup with an unrestrained plastic container under the bonnet with a piece of rag stuck in the top as a cap![]()
OK been looking at this with great interest.
i took think i might be able to sort some waste cooking oil.but how are you filtering it.the preheating i can work out thanks to your photo's
Love the coolant hook up
dieselveg.com(wolverhampton) have done a successful conversion of your vehicle to run on waste veg oil.if your serious aj then what your talking about is a 25/75 mix a lot of people run a 40/60 mix now then 75/25 in the warmer months. i'd personally not rec. a single tank thou' and if you read thro' what i've said previous my reasons why! but thats my opinion. i personally have never used virgin oil so don't know if it also waxes up and thickens on cold days.
if you do decide to try i'd suggest disconnectin' your flow and return pipes diesel and add pipes to your fuel pump plus a filter on the flow and put these pipes into a 1/2/3 litre bottle of v.oil after warming your engine up a bit and warming the oil a bit(less stress on pump) and see if theres any noticeable diff. to your engine!
theres a few companies who are doing biodiesel (different process and conforming to en standards) @65p, i know of one in manchester and one in bridgnorthbig savings if you or a m8 pass that way!
if anybody go's down any path with veg oil i strongly suggest changing engine oil twice as often!
