mildred
Greetings all!
I know that the *choice* of which type to use is highly contentious around here.
but if we can put my reasons aside for a moment [1], I'd like to find out the ways to get best results from a starter type battery - probably a second hand one from a breakers that seems OK on a drop test when used for power in the back end of the van.
LED lighting must help - I've already cobbled together strings of LED party lights so that they work off 12V rather than the originally intended 4.5V and I've already posted about modifying Poundland camping lights. The difference in the current drain for a given amount of ambient light is remarkable.
I've found an LED headlight to be very useful too - localised light for reading or other tasks.
I have a 12V water pump for the sink, but no TV. The fridge needs the electric for the igniter but I don't run it off 12V for cooling! I do *require* use of a net-book which pulls 2.5A at 12V.
The van is hook-up friendly and I have a 4-stage "intelligent" battery charger as well as a ZIG unit. I carry a digital test meter. I know the voltages for different states of charge.
How then to maximise (in terms of length of service and effectiveness) use of a "standard" lead acid battery for "leisure" use?
Currently(!) I'm thinking along these lines.
What do you all think of this regime? What have I missed? Where might I be in error? Remember that sorting this makes the difference between using the van and not using the van ...
Regards,
MildRed
[1] Which are quite simple - economy. I'm down to the point where the extra money to buy a "leisure" battery means I can't go anywhere in the van for several months.
- Buy the largest capacity I can afford that will fit in the space available
- Fully charge it with the 4-stage before leaving home
- Disconnect it from the vehicle charging system
- Be paranoid about state of charge and plan to do something at 60%
- Do something before 50%
- Charge using the 4-stage charger whenever possible rather than blast it from the alternator
Regards,
MildRed
