stop/tail light fault
2CRAZYCAMPERS
First of all like to say thanks to everyone for all the help xmas time
(motorhome wont start) new battery needed £82 not bad i guess.
Well can anyone help we have 2008 peugeot 2.2 boxer avantgard.
Stop/tail light fail x2, new bulbs fitted but only lights work no break lights still?
Changed fuse dont seem tobe that.
loose/broken wire on brake light switch ?
check fuses with a multimeter...dont rely on handbook or fusebox cover location for the correct fuse.
If not fuse or switch, check 'earth' connections in rear light clusters.
Paol
Breaklights but tail lights work... Hmmmm.... I would look for the switch, often its a pressure switch near the master cylinder. check with meter you have power in then get the better half to press the pedal and see if you get power out the other side. Sometimes the switch is mechanical near the foot pedal.
Not the best description but I'm sure you get the meaning :)
Good luck
hi, thanks for the info on breaklights, turned out tobe faulty connection on conversion took into peugeot fixed it for free well done to them and for me
