jamesmarshall
I want to put an extra spare wheel on the rear door of my 06 Transit. Anybody got any ideas where I could get a bracket to suit?
just looked at one on e-bay and it's door hung.if you use one of these then the door will need quite heavy bracing as the metal is so thin for the weight.first one i did i braced the inside with layers of 18mm ply glued to the door then metal strap and it still split.better if you can support it from the hinges or up from the towbar
This might be of some use to you you can go back to begining the link is at bottom of page
Renault Master Conversion
I trick I saw on another van which I thought a good idea was to mount the wheel "dish side" out. This provided storage space for tow rope and old waterproof clothes etc., handy when changing the tyre as it is always raining when I have to do it!.
John
hi joguk.
the reason is some doors rip their outer skin off with the weight of the wheel.
QUOTE]
Good point:egg: Should have said the reinforcing plate on the inside should be big enough to cover the flat flange of the door frame ribs to door skin contact areas. (or weld in some extra ribs)
Thule used to make a very good bike/ski rack designed for 4 X4's that would fit to rear door mounted wheels. It fitted to the mounting studs behind the wheel so could be used with or without the wheel in place (I have a PDF file info sheet on it). Two birds with one stone so to speak:lol-053:
John
