landoboguy
Im adding extra solar, batteries and controllers to my rig, and stumbled upon this.
Some decent info may help less inexperienced, and yes some of it is to sell his links (which we can avoid) , USA but info to be gleaned the way he has laid it out, and may help some members none the less.
Solar Wiring Diagrams: https://explorist.life/solarwiringdiagrams
This is my list/index of solar wiring diagrams and parts list. There are currently wiring diagrams and parts lists for nearly 20 different sizes of setups.
CALCULATORS
Power Audit: https://www.explorist.life/what-size-of-solar-system-is-needed-to-power-a-camper/
This power audit is 100% the best way to determine what size of system YOU will need for YOUR electrical demands. It's a fairly lengthy process, but since solar is such a huge investment; it's very important to know how much you need. This articles includes a downloadable spreadsheet that will help you out.
Wire sizing Calculator: https://www.explorist.life/wire-sizing-calculator/
This is a simple calculator that will tell you what size of wire to use for various applications based on the amps of the device, the length of the wire, and the voltage of the source. I, personally, have this one bookmarked on the home screen of my phone I use it so much. If you want to learn more about 'how' and 'why' this calculator works, I have a video here explaining it: https://www.youtube.com/watch?v=ki3WXVR48eM
Alternator Charging Calculator: https://www.explorist.life/alternator-charging-calculator/
If you are planning on charging your house battery bank from your engine's alternator, this calculator will help you decide if you should use an Isolator or a B2B charger and which one (size) in particular, would suit your needs the best.
Solar Charge Controller Calculator: https://www.explorist.life/solar-charge-controller-calculator/
This calculator will help you choose the proper size of charge controller based on the size and number of solar panels in your solar panel array. If you want to learn more about how/why this calculator works, I've got a video here for you: https://youtu.be/MxziHKvTRh8
OTHER RESOURCES
Solar Panels - Series vs Parallel: https://www.explorist.life/solar-panels-series-vs-parallel/
This articles explains why I recommend wiring your solar panels in series for 95% of applications.
How to Wire 12v Lights & Switches: https://www.explorist.life/how-to-wire-12v-lights-switches-2-way-switches-in-a-camper/
This article explains how to wire switches (including 2 way switches) into your 12v accessory circuits that need switches (lights).
AGM vs Lithium Battery Bank: https://www.explorist.life/choosing-a-solar-battery-bank-for-a-camper/
This articles talks about choosing a Lithium battery bank over an AGM battery bank, the financial concerns of this decision, and why buying Lithium is the cheaper long-term choice.
Truck Camper Solar Install: https://youtu.be/Ht1kl37pJ2E
This was a start to finish install of adding a Inverter, charge controller, and solar panels in a Truck Camper with an existing electrical system.
CALCULATORS
OTHER RESOURCES
