Although a pain in the @rse, it could be important to know why the Ctek 250 isn’t charging the van
battery. A couple of areas to check:
a) if the
solar panel isn’t connected through the Ctek 250 then it won’t trickle charge the van
battery. Swapping its
battery connections won’t help either. Instead you’d need to investigate redirecting the
solar controller that is actually connected to your
solar panel.
b) the Ctek 250 starts trickle charging the van
battery when it detects the leisure
battery (LB) is fully charged. I don’t know the exact threshold it uses but wonder if this is not being met either because the LB is old,
battery type/profile is set incorrectly in the Ctek, or there is a background drain on the LB. It would be good to fix any of these issues.
Some general considerations:
If your van
battery and LB are different types then you may need to change the settings in the Ctek if you swap it’s connections.
There have been several evolutions of the Ctek 250 (S to SA to SE). I don’t know if this reverse charging feature was introduced more recently so if yours is an older version it might be worth checking.
Sorry I have only given pointers for further investigation I would do next and no actual solutions. I don’t actually own a Ctek 250SE but nearly did so relying on the theoreticals I picked up at the time.
Good luck!
