Rattling Locker Buttons
iandsm
The press buttons on my overhead lockers all rattle and squeak when driving along, doesn't matter much about the ones at the rear but the noise from the one on the locker nearest the cab is very irritating as this is just a short distance from my ear. Iv'e tried unscrewing the button and screwing it in tight but to no avail as it still moves around. I would be interest to know if anyone has has the same issue and found a solution.
Can you post a photo! Ive had several like this, fixes for me range from , remove button and put a layer of selltape inside the outer housing , next try a small rubber tube slotted over the threaded bar then screw the button upto it to make the rubber compress and take up the slack, also try changing it for a locker that hasnt had as much use
I can see what you mean, I like the idea of a piece of rubber tubing since that would take up some slack, I can see the screw threaded metal pin inside when I take off the button,I will give it a try.
Try some silicone gasket sealer around them, squeese in and clean of excess with a rag.
Try moving the plastic catch (that the latch engages with) back a little so the whole lot is under a bit more tension, that worked for me.
Another fix on a drawer was to put some plastic cupboard stoppers between the back of the front panel and the cabinet, again to put the catch under more tension, that worked to.
Bought my first Motorhome about 3 years ago and was horrified by all of the noises. Cushions into crockery cupboard's and any cupboard with loose items inside. Little rattles from plastic trims around doors etc would not be eliminated. It’s strange how one eventually adapts to the rattles and bangs going on during travel because no matter what one does they seem impossible to stop. If you stop one another rattle emerges. It was a big shock after years of travel with a quiet cay with a caravan in tow but in many ways is more convenient camping.
