Brucey0705
Posting in case anyone is interested. After trying to source new blinds for the camper only to find out they are discontinued I decided to change the pleated blinds myself.
I sourced the blind material from Jon Slade of Conservatory Blinds Express sales@conservatoryblindsexpress.co.uk.
The quality is acceptable but not as good as the original but worth the time and effort for the finished result.
Jon will send samples of their thermal/blackout colours available, I chose one that was similar to existing.
If like me you decide to do this, then when you order state the cut width you require and the number of pleats. (Count your existing and add on 3 )
All materials are of 20mm pleats with thermal / blackout types available (the samples I got were only 18mm wide, but don't worry the actuals are 20mm)
Cost for all blinds including cab was £175 incl VAT & delivery.
Tip
The main problem was the 10mm holes for the top of the blinds in the cab as they could only supply with 6mm holes. I used a vertical drill fitted with a 10mm diam fabric/leather punch instead of a drill bit, I tried drilling the old material as a test but that was a disaster.
The ruler shown in the picture is for support only, the same as the wood blocks.
Hope this helps someone.
If you need any other advice on this then let me know.
Best of luck
Bruce
Tip
Best of luck
Bruce
