Parts supplier recommendations please (plastic pipe clip)
carlosj
Hello, I want to replace a plastic water pipe clip but can't find one via Google as the wrong clips appear, or suppliers don't have them. Can you help with suggesting a supplier please?
The clip is for the pipe feeding the water pump in my Hymer CV. From memory, it's a 15mm pipe, and the clip design is like a circle, where the clip ratchets together when pressed, to tighten on the pipe.
I'm looking for a replacement as I broke it, or would a jubilee clip be ok, as I'm wondering if that would rust inside the tank.
Thanks for any suggestions.
i know exactly what you mean ,a stainless steel jubilee clip will do the job if you can't get a clip- any chandlery like force 4.don't forget to warm up the pipe before tightening
Thanks for your help, I'll try that. Why should I heat the pipe up first please? Do you mean the pipe that fits over the pump, and does the heat make the clip dig in tighter?
that's right,the pipes can be quite stiff and the clip has to squeeze hard to mould it to the corrugations,and that's how jubilee clips get stripped.warming the pipe with a hot air gun or boiling water just makes it all easier !
Wow!! How on earth did you find them?? That is the type I want. :D
And thanks for the advice, I'll give that a go.
years ago i found that they aren't pipe clips- they're hose clips ! i think pipe clips are used to fix pipes to walls ! e bay demands the correct terminology !
