RichardHelen262
Most probably a turbo charger oil seal failure sucking in engine oil till it runs out or goes bang.
Seen a diesel Renault do it when an apprentice put to much oil in after an oil change.Most probably a turbo charger oil seal failure sucking in engine oil till it runs out or goes bang.
Not always so simple on a runaway diesel. Best bet is block the air intake or if you have one fire a CO2 extinguisher up the intake.i think i would have stalled it ?.
The ignition will have already been switched off, the turbo has most likely blown a seal and it is sucking the oil out of the sump and running off that.Am I being daft here, I'm no mechnic but can't the ignition be switched off?
There is no ignition on a diesel, switch only shuts the pump down but its getting fuel from oil being ingested.Am I being daft here, I'm no mechnic but can't the ignition be switched off?
