No 12 volt
snoopie
Hi I have a luna h592 and I've lost all 12 volt power any ideas welcome thanks
There are many many pssibilities so rather than just posting a list of these we need more info so we can eliminate some.
1) Have you lost 12v in the hab area?
2) Have you lost 12v in the cab area?
3) Do you have solar?
4 ) Are you on EHU ?
5) What have you done since you last had 12v?
Once we have this basic detail we can start helping.
Could be one of a gazillion things.
First, test the battery voltage at the terminals with a multimeter, if you've got less than 12 volts then your battery is flat ISH.
Check if your MH has an isolation switch and check that it's switched on.
Check main battery wiring including the earth/negatives.
After that it's probably a check to see if there's power to the control unit/ fuse box (PDU), it could be faulty.
