I have experienced almost exactly the findings of Tidrus@ 0915,which begs the question-how can you get an accurate assesment of a batteries condition/longevity? Have tried 3 dealer/garage outlets and all have insisted that my 2x110ah*s are fine.But despite polishing all my connections and checking charging equipment they still last for barely 1 night.Any thoughts?
Regular garage visits are a waste of time in some cases, as the method's used are somewhat robust in some cases.
A good local
Battery Specialist (not a car or motorhome dealer, can be found on say Yell.com/Yellow Pages) will have the necessary equipment to help, but a simple test can be carried out before visiting such a specialist.
Good Batteries when fully charged will have a normal threshold voltage of say 12.9v. Now, based on having the batteries on charge to take them to full capacity, disconnect anything which can have an influence on the
battery (charge or discharge) and monitor over a 12 hour period. The reading then taken after this time should drop no less than say 12.7v (this is est 25% drop). Any more than this figure is a good indication of
battery failure. If you are
battery banking, perform this check individually to narrow out the suspect
battery as it is well known for 1
battery to cripple an entire bank.
The team on "The Mathew" (a vessel moored next to the SS Great Britain) pulled down an entire row of 8 AGM batteries as a result of just 2 being faulty. Lucky for them we took our very expensive
Battery Computer with us to fizzle out the duff units (the same Z piece of equipment that is found at a
Battery Specialist).
It is also worth knowing that some MH distribution equipment (such as Sargent Panels and Electroblok's on European vans) have a minor drain of approx 0.8 up to 1.3A (Carthago's average is 1.1A with just the display switched on!!), so it's worth turning them off when leaving the van unattended and no EHU (this will also help the guys n gals with
solar panels as you are not loosing this juice you are trying to put in when leaving the van).
Hope some of this helps.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
